MDF boxes with nothing -except wooden bracing- on the inside sounds best to me.
I made some full glassfibre boxes before, I also used to make smaller boxes filled with wool, I used to put poly and/or bitumen on the inside of the box...
It never sounded completely 'right' to me. Tuning with wool helps, but it won't make it sound completely like I want it to...
I do use poly and bitumen to kill resonance and make the box airtight, but I only put it on the outside to maintain the natural sound of an MDF box.
The box I'm currently building:
- material: 30mm MDF
- glue: normal wood-glue where the pieces fit perfectly, PU-glue where the pieces fit, but not 200% perfect.
- screws: Only the amount thats absolutely necessary to keep the box together while the glue is drying. Pre-drilled the holes and used long screws so they can be tightened well.
- bracing: 30mm MDF
- airtightening and resonance killing: 3 layers of 300g/m² glassfibre + poly-resin on the outside of all panels except the baffle; 5 layers of 300g/m² + 1 or 2 thinner 'finishing' layers of glassfibre + poly-resin + 2 layers of bitumen on the baffle
- finishing: black jeans with a thin layer of mousse underneath
I think this should be dead enough for a 12" Peerless XXLS sub and 2 10" Peerless XLS PR's
greetz,
Isabelle
