What box type for your sub(s)?
  • Sealed
    Votes: 254 58%
  • Ported
    Votes: 129 29%
  • IB (Infinite baffle)
    Votes: 55 13%
What do u have, ported, sealed, IB?
23K views 184 replies 112 participants last post by  jhnkvn
I searched and didnt see a thread or poll and im curious what most of you guys use for your sub(s).
Ive had more sealed boxes throughout the years, but im currently doing ported, and i enjoy it better.
I would like to try IB some day, maybe in the GF's next car.
#6 ·
IB and I really like it, i just wish i had a second sub for more output on those days that I want to bounce down the block. but that's not very often so whatever
#7 ·
lots of sealed. i know this is a sq forum, but i wonder if most are doing like a single 10 sealed just to hear the lows, or maybe two 12s sealed for decent output?
#10 · (Edited)
SAZ 1500D
The specs that Jacob at Sundown audio has from his testing are as follows -
POWER : 1970 Watts
AMP VOLTAGE (measured) : 49.25 V
AMP CURRENT (calculated) : 40 A
ACTUAL IMPEDANCE (calculated) : 1.23 ohms
SUPPLY VOLTAGE : 12.85 V
My speaker is a DVC 4 ohm/wired in parallel [ 2 ohms ]
I'm happy with about 1 cu ft stuffed and sealed/ inverse mount on an Image Dynamics IDMAX 12:beerchug:
both for chest thump/car flexing and SQ :cool:
#11 ·
Currently, 1 12 sealed.
At different times in the past, I have used 2 10s ported, 2 12s sealed, and 1 12 sealed. I also have a couple of 15s that I would like to try...just don't have the power or want to give up the space (for 1 or both).
#12 ·
I run a 12" IDMax in a 2 cubic foot ported box @ 32hz. The main reason: efficiency.
Before the IDs, I ran a 10" JVC Arsenal hemp fiber sub in the same box and it was awesome! It beat hard and hit low.
JVC Mobile Entertainment \ 10" Subwoofer - CS-AW8040 \ Introduction
It sounded like the sub was installed in my dash, I could not believe what I was
hearing every time I got in the car...very under rated sub.
I would def. go back to it. Infact, I am;)
#14 ·
How much port area do you have? If yo uare getting port noise then it's not enough. Two of these Momo's from Polk right?
#16 ·
not sure if this is the place for it, but my thread over on CA didnt provide too much help
i have two polk audio mm1040 10" subs. i built a 2.3 cubic foot box tuned to 32hz slot ported box.
according to my calculations it has 31.5 port area. (port is 12" high by 2 5/8 wide)
i looked at the SSA box designs and for a dual ported box for two ssa dcon 10s, they have 28.125 port area.
polk recommended a box that has 27 port area.
on 99.9% of my music its fine as i dont listen to rap, but if i play late night tip, its making some noise for some reason.
someone suggested maybe its mechanical from my subs, they are rated for 700 watts total, im giving ~870. possible, but i dont think so personally. on that song, it takes putting the gain down to almost nothing to get the noise to stop, no way its power or clipping imo.
it is a 128kbps song, thats all i could get my hands on, and all my other music is 320kbps, and no problems with them. perhaps thats what it is.
#21 ·
of course, but why would 1 song cause this noise but no others
#22 ·
iv have had sealed and ported. i had a JL 8W7 in the recommended ported box. it was a bit boomy for me it didint have the same attack as it did in a sealed box.
i now have an idmax in a sealed box. but i have head room problems (only 225w rms)
#24 ·
I have had in the past simple tuned port and single reflex bandpass for DB drag. For SQ I use 3 10's in a sealed enclosure. Great frequency response and so far I have not had a problem with low frequency reproduction. I did have a set of 12's in a hatch back in a sealed enclosure that was unbelievable they were bazooka 12's with a bazooka amp. Not sure on the power of the amp it was quite a few years ago.
#25 ·
Got your ssf on the amp turned up high enough?
could be there is considerable low freq information below the tuning frequency of your enclosure. Just a guess.
#26 ·
I'll have to check again but ithink it's set at 30hz
#27 ·
sealed leading the way, interesting, but should have known
#28 ·
I've went back & forth between sealed & ported over the last 18 years, but just recently went IB with two AE IB15s & absolutely love them.
#29 ·
^^definately acoustically transparent subs, heard them at MECA finals.
#30 ·
if i had a trunk, i would go ib with ae as well, but i drive trucks or sports cars so pretty much no trunks
#31 ·
Check out their AV line if you haven't already.
#32 ·
i would love to run the av line or a shiva/tempest, but i already have decent subs and cant get any interest in someone buying them for me to buy new. :(
#33 ·
I wouldn't mind trying an IB setup, however my current and all my other previous subs all been in a sealed enclosure
I'm not much of bass though
