Please read everything before commenting, not to sound rude, I just feel that everything I'm mentioning is important to the solution of this. I'm trying my best to only go into critical detail but there is quite a bit I need to cover.
Ok so I installed a soundsystem about 14 months ago. It consists of a Fi Q 12" sub hooked to an Audioque 1200d (at 1200 rms) and a pair of Hertz HSK 165s hooked to a JL 300/4 (each at 150 rms bridged). I have 0 gauge wire going back from my battery to a dist block where 4 gauge wire goes to each amp.
Worked fine for about 8 months and then around 6 months ago I first started noticing my speakers would cut out intermittently. Over the months I have had days where this has happened a lot, days where its happened once or twice all day (most commonly), and days (and even weeks) where it hasn't happened once. Now through this all, the subwoofer NEVER cuts out. only the midbasses and tweeters hooked to the JL.
Now, I finally got around to checking voltages on the amps. I should mention last week was one of the weeks it was mysteriously working fine once again. I had just reinstalled my subwoofer and was playing lots of loud bassy and demanding music all week and no cut out. At this time (when I fixed my gain settings a bit) I also tested my direct volts to each amp and it was reading in the low 13s, which was no more than a volt or so below what the car battery volts were at (I have a meter up front). Still seems kind of low, but I didn't worry about it that much.
Today, however the problem has become the worst it's ever been. I literally haven't been able to listen to my speakers all day because it just constantly cuts out if I play anything over around 50% volume. My charged volts at the battery are still like they should be (high 13s - low 15s unless under a lot of stress in which case they will drop to no more than 12.6 before charging back up). However at the amps the volts were reading at 10-11v, even dipping into the 9s. I turned down the speakers so that not much demand was being placed and so that they stopped cutting out and the amps stayed at ~10.5 while the battery remained at 13.9. It is the same voltage for both amps and I have no idea why or why only the midbasses and tweeters cut out but not the sub. Why am I losing so many volts? Is my alt bad? I should also mention that my alt and battery were both replaced around 11 months ago and the alt (should be) 135 amps as that is what the stock one is rated at (unless they somehow put in the wrong alt at the shop). I think this should be able to handle my system and I can't believe it would already be going bad, but I don't know what else to think.
