Wiring 2 component sets to 1 crossover?
1.9K views 4 replies 3 participants last post by  Jstaguy24
I have 2 Polk audio dxi 6.5 components. I slipped with a screwdriver and broke a section of the crossover circuit board off. NOw I am short one crossover. So can you run 2 mids and 2 tweeters off one crossover? I know it will change the ohm load on the amp, but other then that will it work?
#2 ·
Yes it will "work" but it wont sound as good as it would as if you had separate xovers per set of components. The xovers are designed by many parameters; one being impedance. When that changes, the components of the xover should also change. Replacements shouldnt be too hard to find.
#5 ·
I Could go active. I have an eclipse 3242 4 channel amp, and a Polk pa660 4 channel amp. So I have 8 channels to work with. I have jbl 4x6 cOmponent plates in the dash location. Was going to do a 6.5 component set in the kicks. Possibly the second set in the doors. And I have a Set of 6.5 inch Polk dxi 2 ways in the rear. Which I was going to wire so I could turn them off when I don't want the rear fill.
