Built this little system over the past week, a generation of truck i have never worked on before. but as usual with trucks, i love the fact that i can stand up or sit in a chair and work on them, versus having to crunch down and bent at weird angles all day lol.
thanks goes out to Marc aka msall150 for his helpful tips on this truck as he has the same vehicle.
the goals for the truck were pretty simple:
1. overall decent sound from a simple passive system and a limited budget
2. have the system be out of sight for hte most part and eat up little or no usable space.
thats pretty much it. this is one of hte more simple installs, as i usually tend to do either active setup with full dsp and custom locations, or relatively simple installs with one or two amps running passive in stock locations
anyway, lets get started.
the signal starts with a kenwood 6019 navigation dvd headunit. supplied by the customer:
he also gave me a rear view camera license plate frame, which i installed here:
*note to self, wait for a dry day before crawling under the truck to run cables, drinking dirty water dripping from the body for a few hours sux big time lol.
here is the image on the headunit:
the Front stage was a pair of Image dynamics XS57 5x7" components (mounted coaxially) in the stock location. so nothing too fancy here, the door was sound proofed and new wires run into the door:
its a rather intersted design in that the plastic door car buts right up against the metal opening, and the speaker sorts bolts to screw holders in the metal but also sandwiches the plastic door car too. so i slapped some sound proofing on the part of hte door card that directly contacts the speaker for good measure:
i got lucky here, the xs57 is a direct fit replacement for the stock 6x8s, i mean the screw holes line up perfectly, i just had to chop off the mounting brackets at the two ends. and voila, perfectly secure mounting via stock hardware:
this process was repeated for the passenger side:
