Butler Amp - Hybrid Tube TD-750 Phaze
9.1K views 12 replies 5 participants last post by  jrdclcsw
#1 · (Edited)
Butler/Phaze Audio TD-750 Hybrid Tube Amp
Used, Upgraded, Modded, Working Perfect, Better than stock
On Buyer
Guys, This is a very neat amplifier. I had only heard about Butler Audio (Phaze) and had never owned one I so I sat out to find me a unit to try. I did find this unit on Ebay which I purchased and tryed and was not over impressed while it did have a nice sound. I had never owned a tube amp before so I had NO idea what they were like/about. I had sent a message to victor asking questions about the tube portion and we also exchanged pics etc. He recommended that I purchase a High End set of NOS RCA/(Tung Sol) 5881 tubes for this unit. One issue is the tubes on these units are soldered in and have no Socket. I did purchase the tube set ($100 for the 2 shipped) and began fiddling. I removed the old tubes and for curiousity I played the unit with no tubes. WOW, something was wrong it sounded exactly the same!!!
I stopped right there, ran to my computer and emailed Victor. To my amazement he notified me that Butler had installed a 'Bypass circuit' that allowed these Butler/Phase amplifiers to continue playing once, if, at the time that these Russian made original tubes no longer work. SO, guess what? The tubes had never worked the entire time I had owned the amplifier and I had only heard the solid state portion of the amplifier working. Once the RCA tubes were here I installed them and powered unit it. I did note that the lower portion of the new tubes had a nice glow.
WOW, the difference with the Tube preamp section working is significant. This amplifier is now One of a Kind. It has some of the nicest Preamp tubes offered and working/installed. WAY better than a factory unit. If you are something who enjoys the tube sound in car audio this is your chance. Not sure if you can run a tube preamp in front of those or not guess thats a Victor question.
Thanks to Victor for the knowledge!
Save
#2 ·
bump,
I figured someone would be all over this one of a kind unit
Save
#3 ·
Hi, I have most of the tube drivers in my car including the LD-2, LDX-23, and 3 TD-1500.
Your thread caused my attention and I'd like to know that
when you said "The tubes had never worked the entire time
I had owned the amplifier and I had only heard the solid state portion of the amplifier working." ,
did you mean that the tubes were not working while they're pluged?
I knew that the amplifier would work without the tubes but it never
came up to me that it would sound the same without the tubes...
Thank you.
#8 ·
to clarify, unless you know without a doubt the tubes themselves installed OR NOT, can be non functioning. In my case the old tubes did not light. Once removed the amp sounded the same and there was not a difference until I installed new tubes.
Thanks
Save
#4 ·
I`m surprised Jeremy decided not to solder sockets onto that tube board and eliminate tube resoldering every time you decide to replace tubes.
TD750 is first generation of Butler tube drivers and according to BK Butler himself was designed with bypass circuit to keep amp operational when/if tubes burned down, in later designs that feature was eliminated and newer amps will not produce sound it tubes burned down, so if you have Butler with dead channels high probability is that tubes burned and needed replacement.
Jeremy went all way out with those RCA tubes as they about as good as it gets for that type of glass.
Save
#6 ·
Why, 12ax7 better tube. You can use octal socketed tubes in 9 pin sockets with converter.
5881 more suited for 12AU7 substitute gain wise.
Save
#10 ·
Make me offers on this one of a kind amp!!
Save
#11 ·
Biggest watch forum on the net only allow sellers to post in for sale thread, perhaps great feature needed to be implemented here.
Save
#12 ·
Bump for sweet amp, $420
Save
#13 ·
I'm interested in this amp. I have one for my rear speakers and would like the other for my front speakers. However, I'm unclear. Are there working tubes in the amp or not? I would very much prefer to have one with working tubes, but would take it without for a reduced price.
thanks
John
You have insufficient privileges to reply here.
Featured vehicles
Explore custom vehicles by our forum members. Click a card for details or add your own!
Loading…
