cutting the door metal
11K views 21 replies 18 participants last post by  effenay
Well I was just about to finish everything and put the speakers in the doors. The factory door speaker holesare not big enough to accomodate theCA18s. What would be the best way/method to making the whole a little bigger?
#3 ·
I used a dremel, each door used up a whole cutting wheel though. I threw off mad sparks, and at one point one of the wheels cracked and threw off a shard. It probably wasn't the ideal tool for the job, but tin snips would be really slow i'd imagine.
#6 ·
how about one of those heavy-duty scisors that cut sheet metal and fencing? I used it to cut all sorts of things, but never on the door metal itself. It should work in theory but you gotta muscle it down.
#10 ·
Well, the only tools I currently have that could possible do the job are a hacksaw and a power drill. The dremmel tool is a special bit for the power drill, right?
If it was a small jig saw, I think I could use it.
Basically, the factory hole is not a circle, it's an oval and it's slightly angled going upward from left to right. After putting the baffle over the hole, their is some metal in the lower-left part of the hole. The speaker goes in 95% percent of the way before the basket hits that metal. I don't think it will take too much to make it big enough for the speaker.
What is a zip tool?
#17 ·
If you absolutely HAVE to use only a power drill, you could outline the new shape w/a black magic marker and then drill the outline out...It might take a while depending on how large an area you need to cut out but by drilling holes and then 'connecting the dots' w/a saw or snips, you could do it....
Does that make sense?? But for $25-30 you could get a basic jigsaw or dremel....
Jeremy
#19 ·
Whatever's cheaper betweet the jigsaw and dremel I'd say....though I will say this, to me it was a little easier using the jigsaw because it keeps you at a set height and stable. With the dremel, you have to have a steady hand and control everything more. I like the dremel more for 'fine tuning' cuts,etc...
I paid about $25 for my Black and Decker jigsaw from HD a few years ago and still works great...I've built 5 sealed and ported boxes, cut metal doors and it's done great....
Jeremy
#21 ·
I'd suggest buying a Dremel just to have one. They tend to come in handy quite often. Rotozip is the bigger brother and the more heavy duty of the two.
I used my Dremel with the cutting wheel on my old Ranger, making room for some old 6x9s to go in the doors, lol. The lack of deadening pretty much made bass unbearable, but it did better than the tiny 4" ones up in the dash, lol. Buy extra cutting wheels. You'll use quite a few and break a few more. Besides that, it really is quick and easy, cuts like butter. The sparks will entertain you while you cut. :D
I tried a scroll saw first, ended up breaking the only, and quite old blade I could find. That worked well prior to breakage. The Dremel was option two, and it actually worked out a lot better than expected. I wonder if you could buy a thin carbide wheel for it...
