I'm going to be ripping CDs using dBpoweramp CD Ripper (PC) for use in my Kenwood DMX906S that can read 16-192 kHz/16-24 bit FLAC files.
CD Ripper doesn't allow specific sampling/bit selection, but instead a Lossless Encoding selection from Uncompressed, 0-8.
They say, "Compression affects how much effort goes into compressing the audio, all compression modes give the same decoded audio (it is lossless after all), the higher compression levels will give a small % file size saving, but will require more time to compress and decompress. Compression Level 0 requires the least compression time, whilst Compression Level 8 the most. Uncompressed is a special compression mode with stores 16 bit audio in an uncompressed state."
What are you folks typically selecting?
And, what if any DSP/Action functions are you using?
