The download link was posted on the Audiotec-Fischer site... and then quickly removed.
Reloading DSP... I hope it does the trick.Something is OFF, I use a Match UP10 DSP. Just loaded the new software, using the same setup, EQs and TA, but the sound is completely different, sounds really bad. And since the ACO Version is different, I can not go back to PC Tool 5.
Anyone had this same problem?
Or how can I return the Match to it's previous setup?
Worked for me, I was able to download and save to desktop - and I don't even need it!They removed it..... When I clicked on the link, and then try to download, I was taken to a 404 page....
I have the Helix Ultra S, so I was really hoping to get a look at it....
I think the filter selection needs a rethink - There were some serious bugs here on PCT5 (like it looking like you've got a Low Shelf selected, sometimes showing, sometimes not on clicking to another band and back). Shame if those have carried over"Disabling" allpass filters is still glitched at times.
1. Enable all pass filter
2. Decide it was not needed
3. Change the eq type of that band to something else
4. All pass is still active until you change values of the new eq type.(Color of the eq band is for all pass aswell)
I think the behaviour was same for dsp tool 5 aswell, in my opinion it would be great if the allpass would get disabled correctly everytime when changing the eq band type.
You can just load pc tool 5 and connect it and it will just reload that tools aco drivers 👍🏼 then load the old setup you were happy withSomething is OFF, I use a Match UP10 DSP. Just loaded the new software, using the same setup, EQs and TA, but the sound is completely different, sounds really bad. And since the ACO Version is different, I can not go back to PC Tool 5.
Import sounds right - first time round mine sounded awful. No clue why. Left it, tried again, absolutely fine.You can just load pc tool 5 and connect it and it will just reload that tools aco drivers 👍🏼 then load the old setup you were happy with
general feedback is that pc tool 6 and its algorithms make a tiny improvement to the sound so I’d suspect something got mixed up on import… very strange that it isn’t as good
Hopefully it’s that simple 👍🏼Import sounds right - first time round mine sounded awful. No clue why. Left it, tried again, absolutely fine.
It was odd - the first time round, it didn't seem to import any of the bits in the tick list (the Load... checkboxes, regardless of whether I did Load All, or checked them all).Hopefully it’s that simple 👍🏼
Which version and Dsp please and I’ll pass it on 👍🏼I've been getting some random glitches in the past 24 hrs...
Random turning off of channels when in the tool working, channel will be selected as active but sound becomes muted. Button becomes non responsive.
Did you not save it to the pc also? Always save it to the pc, I don’t think I’ve ever had a setup fail to save to the pc when I’ve saved it to a slotWas doing a tune last night, hit save when out of the software and the system went back to previous tune like it never happened. And the other tunes I had messed up too. I'm going back to 5 until this is released for a final. Cause a lot was done and the system started to sound dead on....
Helix MK3 Pro.Which version and Dsp please and I’ll pass it on 👍🏼
It did auto save and saved directly to the PC. Still was messed. Had no subwoofer playing. Tried to restart the tune, turn the mute on and off. Nothing worked. So I went back to 5 and will use it until all the bugs are out.Did you not save it to the pc also? Always save it to the pc, I don’t think I’ve ever had a setup fail to save to the pc when I’ve saved it to a slot
It did auto save and We saved directly to the PC. Still was messed. Had no subwoofer playing. Tried to restart the tune, turn the mute on and off. Nothing worked. So I went back to 5 and will use it until all the bugs are out.Did you not save it to the pc also? Always save it to the pc, I don’t think I’ve ever had a setup fail to save to the pc when I’ve saved it to a slot
