I'll be honest, I am trying to get enough posts to be able to sell my speakers in the classified section but I just can't stand not adding anything constructive to threads or just contributing couple sentence responses so I thought I might post how I have my iPod connected to my system completely digitally and see if anyone has any questions.
First off I want to acknowledge that I realize it is kind of ridiculous to connect your iPod digitally. The SQ improvements over an analog interconnect are going to be marginal at best. I just wanted to see if it could be done, and I had a deck with a digital in so I went about it. And really, with some of the ridiculous things people spend money on that has no discernible effect on sound quality (hi expensive wire) connecting your ipod digitally isn't the stupidest thing ever done in the name of sound quality.
I started out with this project when it became a chore (and dangerous) to look through my CD folder of ~350 cds to find some music while in my car. Not to mention the risk of them being stolen. I also realized I probably wasn't very good at "shuffling" my selections and ended up listening to the same CDs all the time so having a digital audio player in my car would be ideal. I didn't have an MP3 player at the time, and given my disdain for everything iTunes I actually wasn't planning on buying an iPod. I figured there had to be some sort of niche player out there with a digital output. I was wrong. As best as I can tell the only "standard" mp3 players with a digital output were the iRiver H120 and H140. These units are no longer made, are hard disk based, expensive if you even find them, and on and on. At that point I decided I should consider looking at Apple products since they have such a massive user base.
Apple definitely does not make it easy to access a digital signal. There has been some conjecture on Head-Fi that it should be possible to piece together a digital signal but as far as I know no one has actually accomplished it. There are a couple of docking units out there that allow you to plug in your iPod and get a digital signal out. These are all very expensive ($200+) and most are pretty impractical for a car environment. In case you are curious, however, here they are:
Wadia 170i - $370
iLink Portable Music Server - $1999
Onkyo ND-S1 - $200 to $300 and not available in US
Cypher Labs AlgoRhythm - $579
So what is the answer? AirPlay. On newish (iPod touch gen 3 or higher, as well as corresponding iPhones and iPads) iOS (v 4.1+) devices Apple has implemented functionality that allows you to send music and videos to other Apple devices, most notably the AppleTV v2. Audio sent over AirPlay is bit accurate:
Since the Apple TV is impractical to use in a car unless you have some sort of display, and given that I would need a router to use it anyway I opted to for the AirPort Express mentioned in the article above. The AirPort Express is a neat, tiny little router, that very fortunately has optical out. My system is setup as follows:
iPod Touch 3rd Gen -> Airplay to Airport Express -> Optical to Coax converter -> Denon RFX-8250 Deck
And my cost breakdown:
Airport Express (used) - $74
Duracell Power Inverter - $29.95
Stupid mini-optical to toslink cable - $8.49
Optical to Coax converter - $16.99
Total: $129.43
It should be mentioned that the optical connection on the AirPort Express is basically a mini-headphone jack with an optical tip. It's stupid but they're cheap and can be found on Amazon.
Having used it for a couple of months now I'll be honest and say it's not that practical. The problem is that the AirPort Express takes about a minute to boot up each time you start the car. That doesn't seem like that long but on short trips around town it definitely makes a difference. If it was something where I could get the inverter and the iPod to start going automatically it might be different but as it is I have to remember to turn on the inverter each time I start the car, guess when a minute is up and then switch the iPod to AirPlay. The inverter can also be a little noisy at times. That being said, for long trips it is wonderful and to my knowledge I am the only person with an iPod connected to his car stereo digitally so I get to feel like a unique flower. If there are any questions ask away!
Wadia 170i - $370
Source: Stereophile
Total: $129.43
