Getting ready to run the wiring for a f150 Crewcab and have a couple questions.
I prefer running the main power lead, rca's, speaker wires and dsp through the center of the truck from front to back (inside).
1. What is the consensus on the distance needed between the power lead and above listed wires?
2. Should the rca's be kept separate from the speaker wires?
3. Is there a method/process (rubber, insulation etc..) which allows everything to be run together?
JD
JD
