Is there a benefit to increasing amplifier gains even if you don’t need more power?
I ask because I just finished putting in the system in my new car. I was listening to it right after first power up with no tune or gain adjustments (they’re at minimum) and it gets plenty loud with no distortion. I took it up to ~60% on the HU volume and it was probably at the max volume I typically listen to songs I really want to rock out to. I then took it a couple notches further and still no distortion. So now I’m left wondering if I should just leave the gains alone.
I’m thinking worst case I’ll lose some volume with level setting and EQ work, but if after that I still can crank it with no distortion I’m still fine. If I find I need to recoup some volume then I’ll look at the gains.
Does this sound right? I’m just don’t have enough knowledge to know if amps at minimum gain don’t get a solid signal across the 20-20k range, or they have better fidelity with a little nudge on the gains, or something technical that I just don’t know about.
