The causation of the question:
I have some 6.75's going into some 4" coaxials in the dash
with a 3500hz 12db LP/HP crossover inbetween
(I am well aware that crossing over into a 4" at 3.5k is fairly wrong, no need for the flame š )
I was thinking about swapping out the crossovers and maybe lowering the crossover point to
3000hz or 2500hz. I swear I can hear the crossover point between the speakers like the woofer crosses over quicker than the "tweeter" picks up, kinda like the woofer/tweeter just arnt matching up and the woofer should be crossed over at like 4k or just let be rolled off.
The current crossovers have a 0db/-3db switch for tweets and the issue does seem less pronounced when on the 0db setting.
Different eq or songs, tweets or dash coaxials it seems like there is always a "depression" in the audio like there is a big ol frequency curve trough in the woofers right where the crossover point happens.
Interestingly enough it also seems to more or less go away if I crank up the volume into "deafening territory" step out of the car and just stare at it.
I've chalked it up to cheap woofers or car acoustics, but maybe.. just maybe it's due to beaming of the woofer and maybe the crossover is set too high
and is just a bit junky.... I have noticed it seems to improve if I dip my head way down by the shifter, like I dropped
something on the floorboard which is why I somewhat suspect beaming as a partial issue.
Could be a phase issue that I don't understand? Some impedance spike issue with the components that I dont understand? 0_0
My curiosity is a 2.. or 3... or 4 parter...
Could a relatively ****e crossover design with low quality components cause an issue like this?
Who makes quality crossovers? and
whatchall think? 3.5k? 3k? 2.5k? lower? ... Higher?!? "Blasphmeny!" you say, but fuq idk haha
I think 3k wouldn't be enough of a difference to make much impact. (probably not even noticable in the real world)
I think 2.5k might raise the soundstage a smidge (It's already above where I would want it at)
Partially think just stay at 3.5k and just get a better quality crossover in there and call it a day.
Am I just chasing a ghost? Current crossover uses electrolitic caps and seems most xovers use "film capacitors"
I aint no scientistcallister but from what I read film caps have some benifit in terms of sound reproduction...
albiet.. likely non noticable...? 0_o
Idk.. anyway there seems to be about a million and one crossovers out there in the world of the internet are they all the same or
is there something I should look out for? or am I barking up the wrong tree in a thunderstorm?
Any thoughts are appreciated
Also like most anyone I'm not trying to assualt my wallet š
Morel and audio frog typa stuff aint in the cards... Kindly keep any suggestions in the pleb territory š.
