61 - 80 of 146 Posts
Lol I love sound treatment threads. 🤣 I don't know what's funnier the the ppl suggesting or the ppl that get offended by the suggestions. Ressonix is the best, everything else still works( just not as good). Choose something that's within your budget, doesn't melt, and doesn't smell like ass.....phalt.
@Chris Purdue. I'll be using the D4S deadner in my next project. Still haven't bought all of it yet, but I'll be using a combo of their 200,120,80mil . If it's alright with you I want to sent a piece of each to you. Just to add to the list of already tested. 😃
Absolutely. Send me a dm, or email me at sounddeadeningtesting@gmail.com
I put about 100 sq. ft. of deadener in my car, that's not doubling up layers, just what it takes to hit most of the surfaces, and I didn't even do the floor of the cabin.
Cost me about $200
Resonix would be $1,350
Is there really going to be 5 times the performance?
I also used 15 feet of 3M Thinsulate 400, $135, so I'm still a grand cheaper.
To me, it's not worth the extra money for minimal return on investment.
Depends on which product you used. I recently tested this exact theory. I used Resonix and Resonix Mega as they are the current most expensive products, and the highest performing products. I compared them against the products that have some of the highest amount of reviews on Amazon, Killmat 80mil and Noico. I already knew from previous testing that one to one testing wasn't going to be equal. I made a guess, and cut one 5.5"x5.5" piece of Resonix and Resonix Mega. I cut three 10"x10" pieces of Killmat 80mil, and two 10"x10" pieces of Noico. It took two 10"x10" pieces of Killmat 80mil, layered on top of each other, to come close to the performance of an 5.5"x5.5" piece of Resonix, on the 11"x11" test panel. And even then, it still wasn't quite as good. Doing the math, that's 6.6 times as much Killmat 80mil. That makes it cost more money for the Killmat than the Resonix for the same performance. Of course, if you don't need that level of performance, that's a choice you'll have to make. But the idea that you can just buy more of a cheaper product for the same performance doesn't always pan out. It didn't with Noico or Killmat 80mil.
Unlike speakers, there is actual testing and data that proves one is better than the other. Whether or not one chooses to believe the data. That is for them to decide. Testing data backs up the claim that ResoNix is one of if not the best CLD out there. There the controversy starts is whether or not the added price for said better product is necessary and worth it. Then you simply have the hatters that will bash it no matter what.
I will throw my hat in the ring!
I suppose this is what it all boils down to and why these threads trigger me.
No matter the budget ot goal of someone asking for deadener suggestions, people suggest the most expensive option, same thing happens with speakers.
Sommeone on a budget that just wants to help their doors or trunk, and has $500 into their entire system won't spend $2k on deadener. Those same people that dont have 9" door speakers on 400w might not need the highest performance option either.
I certainly understand your point. I used a mix of products including Resonix Fibermat and CLD. I used Thinsulate and good ole MLV. My entire sound system was under 2k not including deadening. The way I thought about it was that I was deadening once, components may come and go……..and I DO have SI TM8 in my doors! as part of a two way front stage only system. I feel it is good for inquiring minds to get ALL the ideas, pricey or not and then they can decide!
I get suggesting better products more with CLD than I do with speakers. Speakers are a relatively low risk decision. If it doesn't perform well, you can remove them, recoup a good amount of their cost, and move on to the next.
But you can't really do that with CLD. With CLD, if you find that it didn't perform well enough for your needs, you can't recoup any of the cost. I've seen too many people install a lower performing product, and then end up spending more than they would have with a better performing product trying to chase the performance they were after with layering or other diminished return install methods. I've even seen people buy expensive high performing product and put it on top of a cheaper low performing product because the first product didn't reach their expectations, which is worse than just buying the more expensive product the first time.
I mean, realistically, that's the whole reason I started testing. Because the first time I treated my vehicle, I spent way more money than I needed, because there was no testing, and there was a ton of misinformation out there. I could have easily gotten the same results, for less money, using better products for the job.
You asked specifically if Resonix would be 5 times better than what you used. My response is, it completely depends on what you used. It is absolutely 5 times better than some other products out there.
Well stated Chris. Deadening IS a foundational product!
I think what I am gathering from everyone and the data posted is that the performance of the better products is better than worse products even when spending the same amount. Looks like the only thing to weigh is whether or not you can budget for the initial buy-in of a better product.
I appreciate all of your testing, it kept me from picking up the CLD I had by eye on and installing a sub-par (for my needs) product. Since I'm installing it on a fiberglass Jeep hard top it would be far more difficult to remove than from metal, so if I buy wrong I cry forever.
Your information about how well Resonix performs with partial coverage is what ultimately sold me, and I'll be buying some after I get my Jeep's electrical performance upgraded.
Thank you, and welcome back!
Not always, but often. It’s a risk every person has to decide on themselves. My goal is to educate people on the risk. Essentially, if you decide you are ok with a lower level of performance, and once installed, you are happy with it, then great. But if you think that you can get the performance you want for less, and find out after the product you chose doesn’t meet your expectations, you’re now stuck spending more than if you had used the better product to start with. I found myself in that position the first time I built my car, and my goal with testing is to educate everyone else so they don’t end up in that same position.
Might as well throw my hat into the ring too. I just laid up some of this NVX and like the way it rolled on, very tacky.
This works pretty well too
Only in the 120ml or thicker stuff though. The 80ml peels up around the edges, no Bueno!
The best I've ever used is a product that Elemental Designs used to sell called E-dead, the stuff was the bomb! I would buy it in 50 square foot rolls. It was very much like what Resonix puts out today.
If it's sold on a roll, then its nothing like what Resonix puts out. Rolling the product damages its performance. This has been shown in multiple tests.
NVX performed very well, my only concern is its heat performance. There have been rumors that it's made in the same place that makes KnuKonceptz, which had issues melting. I can't confirm that, but I can't recommend it until I get it on the heat test rig.
Siless 80 mil performed pretty poorly. The 120 mil probably performs better, but not likely enough to put it in the top catagory.
Well, I should have saids it looks simlar, no way to know if is anything like it, no way to compare asI have not purchased Resonix.
That said, the E-dead used an alloy-impregnated/ infused polymer layer instead of straight aluminum foil which didn't have the issues you are talking about. The issue with rolling it is that the foil buckles and when applying it creates a lot of air pockets (or it stretches/delaminates from the substrate). The stuff worked amazing and stuck like glue, conformed to any angle or curve, miss it! And like Resonix, it was expensive.
As for the others, yeah, didn't notice the applications noted in the thread, was commenting on interior panels where I don't see an issue at all. I heated the panels in my oven at 170-200 to warm them up, got pliable but no issue actually melting. For the interior, should be fine.
here is a picture of two layers of it in the back end of the Suzuki hatchback I used to own. Not my best work but by the time I got to the rear of the car, was ready to be done!
The wrinkly mess you see is actually the factory deadening under the layers that they sprayed on. That is a picture taken today from a install I did in 2006. The car was recently totaled and is getting ready for the big car wrecking yard in the sky.
Ha, found an actual picture of the stuff I was talking about. It was 120ml thick, very unusual, innovative and ahead of its day back in 2006 when I did a car with it. Elemental Designs made really good stuff and had a very good following.
E-Dead was a rubber/asphalt mix, which never performed well, compare to actual butyl products. It also had a very thin constraining layer, which doesn't help performance. Lastly, I've heard of many people having E-Dead fail on them.
Now that could possibly explain why they are no longer around!!
