Test Tones & Test & Setup Track Repository - Please Contribute Tracks & Techniques
So I wanted to start a Repository of sorts for the most common Test Tracks that we all use to Setup, Measure, and Tune our car audio systems, both By Ear, and with a Measurement Microphone & Software/Apps. PLEASE CONTRIBUTE!
TYPES:
Mono & Stereo
FORMAT:
LOSSLESS WAV files preferred.
Otherwise please submit other LOSSLESS, Uncompressed formats.
NOTE:
MP3, AAC, and other Compressed File Encoders can add Spurious Artifacts to certain test tones OR will apply HPF & LPF which will skew your measurements and trick your ears. So please try to submit or Link to files that are in Full Lossless WAV format if at all possible.
TECHNIQUES & PRINCIPLES:
Please Describe any particular Methods or Processes that you use with a Particular type of test track.
To Start things off, here is a Link to the FREE Focal CD Tools Download
The included "Sourdo" drum track is an excellent one to use to locate door panel or other resonances and buzzing panels.
Another EXCELLENT set of Discs are the Navone Engineering/Autosound 2000 Test CDs: CD#101 thru CD#105
SOFTWARE/APP TONE GENERATORS & RTA:
You can use REW or Audacity (among other free programs) to Create Custom Test Tones & Pink Noise, etc.
And I've been using the "Function Generator" Android app A LOT lately. You can create nearly unlimited types of test tones in real time, and it allows you to easily switch from Left to Right, or mute individual L/R channels.
This makes it easy to quickly balance the Frequency Response of the L & R channels with PN or WN. You can also CHANGE THE PHASE of an individual channel in Real Time. So you can play a test tone in your Left Midbass at 0°, while incrementally changing the Phase ° on your Right Midbass, etc.
A nice little Android RTA is Advanced Spectrum Analyzer PRO or Spectroid.
iOS & Mac users, please post your preferred Programs & Apps.
TYPES:
Mono & Stereo
- Sine Waves & Sine Sweeps
- Pink Noise, White Noise, Brown Noise (Correlated & Uncorrelated, Full Spectrum & Band-Limited)
- Band-Limited "Click" or repetitive On/Off/On/Off tracks.
- Phase
- Others
FORMAT:
NOTE:
