where to get metal rings cut?
1 reading
1.5K views 8 replies 8 participants last post by  Aaron'z 2.5RS/WRX
So I've been making some calls locally and nobody can help. I've found places that plasma cut but that isn't accurate enough for me.
Am I stuck going to a machine shop or is it possible to order some metal rings online and have 'em shipped?
#2 ·
What material, diameter and thickness. Hole locations, tapped, blah blah blah. Let me know what you need and I can help you out. It'd be pretty easy and all you'd need to do is send a mcmaster or metal xpress order to me. They're super fast and relatively inexpensive (depending on material). Then just take care of the shipping costs to you and just a little labor and you'll be set. Could be done and shipped out by friday. A dimensioned drawing would help a lot.
#5 ·
I can probably cut them on my waterjet in acouple weeks after I get my new fixture for what I do regulary, otherwise it isnt worth it to dismantle my fixture and have to reset it up.
But I would lok for a shop with a waterjet, I am assuming it is thinner metal and not hardened, will take 5-10 minutes to cut if that
#7 ·
anything under 6.5" diam, I'd use a bi-metal hole saw for the ID or OD or both... in a drill press, slow & lubed.
if not... find a local waterjet or CNC operator... 3/4" thick steel... or aluminum... serious stuff.
Rob
#9 ·
You could also contact Alro Steel about this, my brother works on a tubing laser for one of there facilities.. He's actually going to laser cut some CF panels for me for logos..
