I have two ONE Zapco Z-150.2 series II amplifier - $375.00 each shipped in Continental US - one of the 2 is now SOLD and shipped.
I have one Zapco Z1KD series II mono amplifier - $325.00 shipped in Continental US - SOLD
PayPal is preferred.
All amps are 9.5/10 due to a couple places where they have minor scuff marks. I had trouble even getting the marks to show on the pics. Amps were used for 18 months in a Tesla. They were professionally installed and uninstalled by the same shop. I purchased them used and intended to use them in my current build but did not really realize how big or heavy they were until I received them. Now that I have them I realize they will not fit with my plans. I had forgotten how big class A/B is. I have all class D currently and may have to get a bigger car if I want to go back to class A/B. Beautiful amplifiers but if they don't fit they won't do me much good.
Here are the specs from Zapco.
Zapco Z-150.2 series II:
Z-150.2 II | ZAPCO
Z-1KD II | ZAPCO
Specifications
Z-150.2 II | ZAPCO
- 2-Channel, Class-AB Sound Quality Amplifier
- Stable into 4 ohms bridged or 2 ohms stereo load
- PWM MOSFET power supply
- High end Op-amps and Capacitors
- Variable FULL / LP / HP Electronic Crossover
- 0-12dB variable bass boost
- 4-way protection circuitry
- Wired remote control (optional)
- Panel mount RCA connectors
- Power @ 4Ω: 2 x 165 watts
- Power @ 2Ω: 2 x 275 watts
- Power @ 4Ω Bridged: 1 x 550 watts
- THD @ Rated Power < 0.05%
- Signal to Noise Ratio > 100dB
- Frequency Response 10Hz to 30,000Hz ±1dB
- Input Sensitivity .5v to 8v
- Dimensions in mm: 190(W) x 62(H) x 301(L) Overall: 190(W) x 62(H) x 328(L)
Mono Class D Linkable, bass amplifier,Stable into 1 Ohm (2 Ohm w/2 amps Linked/Strapped)PWM MOSFET power supply24 dB Variable low pass (LPF) crossover12 dB Variable bass boost equalization0 – 180 degree variable phase shift24 dB Variable subsonic filterSelectable master and slave operation for Linked (strapped) amplifier operation
Power @ 4Ω: 450 wattsPower @ 2Ω: 700 wattsPower @ 1Ω: 1050 wattsLinked @ 2Ω: 1800 WattsTHD @ Rated Power < 0.05%Signal to Noise Ratio > 90dBDamping factor: > 350Efficiency: 86%Input Sensitivity .2v to 8vDimensions in mm: 190(W) x 62(H) x 275(L) Overall: 190(W) x 62(H) x 305(L)
