Hi all,
This was my first system with a DSP so I wanted a pro to install it and learn from the experience. I went to Columbus Car Audio to have the install done. I'd like to personally thank Don(D-Bass) for helping me bounce ideas around of what to install and Dan(danno) for the incredible work done.
What went in:
Here is a before and after of the doors getting their sound deadener.
I had gotten the following sound deadener installed throughout:
hushmat bulk kit 30 12”x23” sheets
2 hustmat silence megabond 1/8”
and a 2 pack of 8” hushmat wave breakers (These went right behind the factory location for the 6 1/2” mid bass)
I’m going to start off with the head unit. The bracket was custom built to flush mount the bottom lip of the 8500 with the trim panel surrounding. The 30 pin apple adaptor is in the glove box and the factory USB location works.
Here’s a close up of the IR repeater added for the Pure i-20 controller. It’s between the vent controls.
And on to the doors.
Here’s the wave breaker mat mounted behind the 6 1/2” door mid base.
If you are going to sound deaden, then go all out.
Here’s where the Mille 3” and tweets went in. I wanted as stock of a look as possible.
Of course more sound deadener was used.
More than a little custom fabrication was done.Here are the Mille 3” mounts.
Here’s the Mille tweeters custom mount bracket.
The foam surrounding the speakers was to seal up the speakers to the factory grills.
Here’s a couple of pics of the custom bracket for the rear voce 3.0.
Did I mention sound deadener?
The cavity behind the 3” rear fill was also filled with it.
Time to cover the amp rack and sub bottom mount.
You can literally pick up the back end of the car holding it by the amp rack.
Here it is all wired up.
Now on to the Sub box.
The fill material used in the box was incredibly quiet. You could hear a difference with your head in there.
Here’s the wall that was built for the floating sub box mount. The front of the sub box had leather glued to it to provide a flush seal and some grip. The back bottom of the sub is held in place by the amp rack. The top back of the sub is anchored to the rear deck with two brackets. Since no part of the sub box is touching the floor of the trunk, it’s a floating mount.
Here’s the trim piece added to show off the sub a little more.
Here a detail photo of blending the sub wall in to the factory panels to make it look like it belonged there all the time.
Here’s where the Audison Voce 1.1 tweeters fit in to the rear panel.
Here’s the assembly of the passive crossover mounts.
Here’s how they look mounted on the sides of the floating Sub box in the finished trunk, without and with coverings.
That concludes the photos. I was planning a video of the last bit not mentioned, but I'm going to be removing that when the PS8 controller comes out and going with a retina iPad mini head unit so.....There is also an Apple TV 3 under the passenger seat. The iDevice I use in the car is an iPad. It's the 3 with the 30 pin connector still. Since there is a HDMI interface on the 8500, the Apple TV uses that connection and comes up on the Pioneer. I hit applications to get to the apple TV. When I want to use the apps on the iPad I put the Apple TV to sleep and it drops me back to the last used screen. From there I navigate back to apps and I have full access to the apps. The goal of the install was as much of a factory look as possible.
I highly recommend Columbus Car Audio if you are in the area. They have been around since 1978 and still are going strong.
D-Bass and danno, if I missed something please chime in.
What went in:
- Hertz Mille MLK 3 PA (Front stage)
- Audison Voce 3.0 and 1.1 with AV CX 2W MH crossover
- Audison Voce AV 12 sub
- 2X Hertz HDP-4 amps
- Arc Audio PS8 DSP
- Pioneer AVH-X8500BHS head unit
- Pure i-20
