I'm getting a little baffled trying to achieve a decent sounding setup. This is an Audiofrog GS component setup (GS10, GS60 and G610C) off a Zapco ST204-D SQ.
Using RTA, I was tweaking the system siting inside my garage, engine off. It didn't take much really, with the tweeters in the sail panels I went down to -3db on the crossovers and that mostly took care of really bright high end stuff, just a little EQ and it was sounding brilliant, really impressed, going between studio monitors and the car and it was very good. Subs not installed yet, but regardless
Going for the first few drives though, any time the volume would be turned up, the high ends would become unbearable, damn near painful and you can feel the fatigue creep in. Assumption being that it's a factor of cranking the volume to beat the car and road noise, with the ears being more sensitive to the high ends.
So then I commenced tweaking it to sound more decent on the open road, it meant some huge EQ cuts which seem ridiculous, but then it's at a point where the cymbals aren't drawing blood out my ears, S's in vocals aren't overpowering everything.
Now though, any time I'm at low speeds or sitting still, you can hear that the overall sound is so muddy and muffled. I then click the head unit back to a more flat EQ and suddenly you feel that "airyness" return.
Is it just a choice I have to make between having a good car park SQ, or SQ at speed?
